I am installing a new shower valve and will be removing the current shower head and replacing it with a hand held shower head supplied from a drop ell fitting which would be lower than the current shower head by about 24”. I am told that this will result in water coming out of both the tub spout and the new hand held shower because there won’t be enough back pressure on the diverter for it to function properly.
Is this true and if so what is the minimum distance from the diverter to the shower supply for it to work properly.
Thank you
