I have a tiny sink in the basement with a hot/cold faucet and a standpipe, for our clothes washer. Got a new washer, and I'm having problems figuring how to attach everything up:
  1. The attachment I have now seems to be a "standpipe adapter" - it has a ribbed nozzle that brings the 1 1/4" washer drain hose down to where it will fit in the standpipe (and it's not easy, I have to shove it in there and attach with zipties so it doesn't fly out when water's coming through it).
  2. When we got the furnace put in, the installers ran a small plastic tube from the furnace into the standpipe. It looks like they gouged a hole out of the old standpipe adapter to get the drain to accept both water sources. (see photo)
My problem is finding a new solution for this:
Standpipe adapters seem to cost up to $50 for the small rubber/vinyl piece, plus a lot of shipping, and they're all brand-specific so I'm not sure if they will fit to a standard drain hose I can get at the hardware store. And none of the ones I've seen so far have the handy groove going all the way down the side like my old one (see photo). In addition, I'm not sure what tool I'd use to drill the new hole. I've seen a few Y-style adapters, but they're also expensive and I'm not sure if they would work right without spending the money to order and try them out.
Any ideas for what is the right part, or the right solution for this kind of problem? I've been leery of hiring a professional installer or plumber for what seems like it should be a $5-10 part. (By the way, that one in the photo won't come off of the old drain, it's either 1 piece or fused completely onto the hose).
Thanks for your help!
  • Can't you leave one of the hoses in the sink with a J hook at its end?
    – r13
    Commented Jan 18, 2022 at 1:13
    Can you post a picture of the standpipe and sink as well?
    – Ariel
    Commented Jan 18, 2022 at 1:29
    Something you might now know is that the washing machine drain is NOT supposed to be air-tight to the standpipe, it needs to be smaller that the standpipe or otherwise vented. I think that's what the strange slot in the side of it is - a place for air to enter.
    – Ariel
    Commented Jan 18, 2022 at 1:30
  • @r13 As you can tell from the photo, it's not a real sink, its just a sink-like box with a standpipe sticking up in the middle.
    – orbfish
    Commented Jan 19, 2022 at 16:36
  • @Ariel posted the photo - hard to see since it's attached, but basically a PVC pipe sticking up in the middle of that box.
    – orbfish
    Commented Jan 19, 2022 at 16:37
That standpipe hole is MUCH too small - it's required to be at least 2", and you said it's less than 1 1/4? You should remove that box and replace it with a good one. Once it's large enough you'll have no trouble putting in the second drain line from the furnace.
How big is the pipe under the box? Is it vented?
This video is helpful for some nuances you might not realize: https://www.youtube.com/watch?v=EzMURfc3Fgo
BTW you don't actually need a box (if you don't have the budget for it), you can literally just stick the drain hose into the top of a PVC pipe, but the pipe must be large enough! And it must be the right height, it must be vented, and you need a trap. (You need all that stuff with a box as well.)
If you like, post some pictures of the drain with the washing machine line removed, and of the PVC under the box.
  • I watched the video - trap and the venting looks good. The standpipe looks like 2", fitted into what looks like a standard box. So the width should be standard? Undoing the hose is hard, I have to balance it back up and add 2 zipties before I can use the washer again (maybe this weekend) - but it appears to be slightly narrower than the 2" pipe. The Maytag line I'm replacing I would guess is 1 1/4 - but I see the new hose I bought on Amazon is actually only a half inch, so that might work. Is there a difference between using a large and small drain hose, or does it maybe vary by manufacturer?
    – orbfish
    Commented Jan 20, 2022 at 3:11
  • I disassembled and got pictures of the washer box. It's a bit hard to be exact, but the hole looks like about 1 1/8 inches (epoxied to the 2" standpipe). I also took a picture of a hose I bought online - it's about 1/2", which would work fine with the second hose, but I'm a little bit worried about too much water through the hose. Is any hose OK? No one at LG is willing to give me details about the size of their hose ends or hose requirements other than "order this standard replacement part."
    – orbfish
    Commented Jan 23, 2022 at 22:59
  • Oh... they didn't cut the ring out correctly +1, which is a pita holding it in your hands... now it's stuck to the wall and pipes are in the way.
    – Mazura
    Commented Jan 24, 2022 at 14:50
  • @orbfish So looks like the hole is 1 inch? How big is the black pipe under it? You might need to just remove and replace that wall box. Or maybe you can cut it larger, but you'll need to remove it, to avoid clogging your pipes with bits of plastic.
    – Ariel
    Commented Jan 24, 2022 at 18:13
    @Ariel Well I couldn't find an outline. Eventually got a plumber in, since I thought the box would need replaced and I didn't think I could handle the copper piping for the water, but he was able to take a small drill bit and drill out a 2" outline at the bottom of the box and pop the edges out without letting plastic fall into the pipe. You got me there thanks for the help!
    – orbfish
    Commented Feb 19, 2022 at 21:06
