My son has been backing chicken with some friends, and now the door of the oven is no longer horizontal, when open, but hanging to the ground. Here is an image:
I guess they have let the oven door fall and some part of the hinge is broken or a bolt has sprung out. When you look at the hinge closely, you can see an empty bolt hole in the part of the hinge that is closest to the oven:
When you look inside the hinge from above, you can see two strips of metal on either side. They seem to have holes in them, too, and I suppose there was a bolt through them to hold the door horizontally above the floor:
I have found many instructions on the internet on how to replace the part of the hinge that is in the door, but few on how to remove the part of the hinge that is in the oven, and none for this model. Also, I don't want to replace the hinge. If possible, I'd like to repair the hinge.
Any ideas? The oven is a Miele H4220E.
