My door lock needs care, the key is hard to put in.
I've got this in my previous apartment and I got some 'magic cream' from a friend which worked like a charm, but unfortunately, I don't have this anymore and I haven't noted what was this.
What kind of lubricant works fine for door locks? I don't want to get it stuck more.
    Graphite power usually works well, does not drip like oils. If key is hard to put in, instead of turning, might be damage to the lock or key.
    Jan 9, 2022 at 17:54
    silicone spray applied to the key works well
    – jsotola
    Jan 9, 2022 at 18:28
  • I use WD-40 or a similar product. You don't need much. Just spray a little on the key and insert it into the lock, and turn it repeatedly. Jan 9, 2022 at 21:00
    Oil holds onto dust, causing future problems. A drop on the key itself might not be too bad, but not in the lock. As @crip659 states, use graphite or powdered PTFE. Jan 9, 2022 at 23:39
  • Stay with dry material like graphite or moly sulfide . Oct 11, 2022 at 16:27
-1
In addition to graphite powder, other lubricants for door lock mechanisms include silicone lube, grease lubrication, and Teflon-based lube. A penetrating liquid like WD-40 or white lithium grease is another option. Consider the local weather conditions before selecting a suitable lubricant.
    I wouldn't put any grease or oil in a door lock mechanism. It'll just make a mess, including on the key, which you then put in your pocket or purse. Also, how many questions are you going to copy/paste this answer to?
    Oct 11, 2022 at 13:46
