I have a walkout basement with 1 long side and 1 shortside above grade... For material usage is this considered above/on grade? since the slab is not really below grade?
I need something like: https://www.homedepot.ca/product/roberts-7300-universal-vinyl-flooring-adhesive/1000851709 which says for concreate above/on but not below.
This is in Ontario, Canada.
  • Seems like any concern would be it soaking with water on top(flood in a basement for a time). Could be mistaken.
    Jan 8, 2022 at 21:11
Slab above grade - an elevated concrete slab not in contact with the ground.
Slab on-grade - a concrete slab cast directly on the ground, that will be influenced by the moisture/water content in the soil, and could become damp, if a vapor barrier is not used.
Your basement is partially below grade (2 sides), but the slab is likely placed on the ground (slab-on-grade, SOG) unless there is a crawl space below.
