My basement lighting is all wired on a single circuit, it used to be one room but previous owners have split off sections. Yet all the lights come on at the same time. The furnace room has a fluorescent fixture in it, however I would like that room to be dark (I'm looking for a place to put a mealworm farm).
In the case I need light again, I'd rather not disconnect and cap the wiring, and instead just pull the bulb, however I know the startup procedure for a fluorescent bulb is special.
Will running a fluorescent fixture without a bulb cause it damage and/or to waste electricity?
