The hot water in my shower leaks and I'm trying to remove the stem but I don't see a hexagon type nut to unscrew.
You should still be able to unscrew that inner unit. Use mole grips or similar just before the brass thread.
There appears to be a notch in the brass ring, there is probably a specific tool to engage in that to turn it.
This is a similar unit, but it does have a hexagonal nut. If you get the unit out, replace it with a new one.
When you refer to "inner unit" are you referring to the dark part just before the brass? I'm unscrewing the dark part and not the brass, correct?– DaniJan 5 at 20:55
Not just the dark part, the brass too. I've added an image to the answer of a typical replacement unit. Jan 5 at 21:16
@Dani: Impossible to say from a picture. They come in different sizes. Either measure it carefully and search online (I did this) or take the dead one to a builders merchant and see what they have. Jan 6 at 8:39
There are flats on the valve body. There's one visible here, and there will be another on the opposing side. Use an adjustable wrench, sliplock plier, or other similar tool.
