I have this reservoir, located in an all-stone wedge in the terrain. The water is held back by a small dam, consisting of granite boulders held together by a mortar.
dam wall
As is evident from the water level, it's not doing its job very well.
How would I go about waterproofing it?
A great number of compounds and membranes seems to exist, of which I do not know the efficiency, but keeping the water food grade seems to limit the options considerably.
Another idea is to just pile up peat, which I have in great supply, in front, but that would be a waste of time if any actual solution would require removing it again first.
  • I have no experience whatsoever about building dams. But beavers do it without mortar all the time. :) And the water is still drinkable. Maybe some wildlife research might provide a decent water-safe solution. Commented Jan 1, 2022 at 14:20
    Don't drink from beaver ponds. It's not the dam materials (sticks and mud,) it's the parasites in the beavers, in the water, and then in you...
    Commented Jan 1, 2022 at 14:39
Plenty of water stored in cement tanks, so a better job of mortaring should do.
Bentonite clay is a different approach, commonly used to seal around drinking water wells and to seal ponds, etc.
Stock treatment of a drinking water pool of this sort would also be to cover it to prevent insects and animals/leaves from fouling it.
