I spent so much time making sure each window was level and plumb that I didn't think to make sure they were equal to each other. Now that they're flashed and nailed, they're about 3/8" off which I can tell when I look at it (not sure anyone can).
My plan is to vinyl side this shop and I'm worried the issue will be exacerbated once the siding goes on. I'm hoping I can tweak the windows so it's not noticeable without having to remove them and start over.
My initial thought was to add 3" trim around the windows and to cut the left one a little larger on the top and a smaller larger on the bottom to level it out. Would this work?
  • 5
    Trick 1: live with it. Trick 2: rip out and redo. Trick 1 tends to be the winner unless you are contractor working for someone else and ignored the plans.
    Dec 30, 2021 at 21:46
  • 6
    You won't notice it. The only reasons you do now are 1) it's fresh in your mind, and 2) there's a seam in the Tyvek right there. Unless you have a siding edge right there it'll fade from memory before long. Almost no one else will ever see it.
    Dec 30, 2021 at 22:29
    Ecnerwal & isherwood are correct. However, your idea of adjusting with the trim is a good one. But I think I would only do it if the trim is going to be a different color than the siding. That would make it a little more noticeable.
    – HoneyDo
    Dec 30, 2021 at 23:53
    You could fiddle the trim (personally, I wouldn't), but if you don't, try to make sure the bottom/top of the windows is around the middle of the siding. (In other words, don't have a siding seam too close to the bottom/top planes.) Dec 31, 2021 at 1:34
    @isherwood every time the OP looks at it they will notice it, especially when the siding goes on and the window height to the next line of siding is different on each window.
    – Huesmann
    Jan 26, 2023 at 12:51
-1
You could grow vines on it. It's also excellent to keep it cool in summer.
    On vinyl siding? Erm....
    Dec 31, 2021 at 20:30
    On any building? Not good for the building...
    May 31, 2022 at 15:06
  • You have to trim it at the top so it doesn't cause leaks in the roof.
    – bobflux
    May 31, 2022 at 15:37
