I currently have a two-wire system (R/W) going to my thermostat. The furnace is an oil heat system with a blower to force air. There is currently a Honeywell R7284 Oil Primary Control where the thermostat wires are running to, both labelled at T T.
I tried looking at the manuals for the system but I'm a little out of my depth as I've not had to mess around with an oil system until I purchased this home, but would like to modernize a bit and add a Wifi Learning Thermostat for convenience.
The cable run up to the wall is pretty straightforward and simple, so I'm hoping one of those other terminals is able to act as a C-wire to provide constant power. Some of the other posts mentioned an F F terminal but mine has a 3/2/1 instead.
Thanks in advance.
