I initially thought it was some type of paint mixer then realized the end would not fit in a drill.
2That end doesn’t seem good for much except hanging on a display hook. Perhaps that’s all it’s for? It looks unnecessarily difficult to clean as a paint mixer though.– Tim BDec 25, 2021 at 18:29
See if you can pull the smaller plastic piece off. Perhaps you are meant to remove it to use the tool and replace it to store the tool.– A. I. BreveleriDec 25, 2021 at 18:40
1The end piece does pull off.– Steve WellensDec 27, 2021 at 5:37
10That is a full-featured ruler.– Eric HauensteinDec 27, 2021 at 13:36
@EricHauenstein Would have been nice to have numbers as well though.– Glen YatesDec 27, 2021 at 21:11
1 Answer
Cyclone paint mixer.
I imagine you just need to remove the hang tag at the drill end.
3That's a bizarre use for a squirrel cage fan! I took apart an over-range microwave oven recently and found nearly the exact assembly inside, perhaps the convection air mover. Perhaps I should not have disposed of the fan assembly, but it was coated with condensed food fumes. Dec 25, 2021 at 19:23
4@fred_dot_u I wouldn’t really call it all that bizarre. Used (and sized) correctly, this type of design can actually ensure that essentially the entirety of the fluid in the container gets mixed (if used and sized correctly, it generates the same type of flow in a circular container as would be produced by convection currents). Dec 26, 2021 at 3:09
2Do not use for whipping up milkshake after mixing paint. Order of operations is important.– Bill KDec 28, 2021 at 18:53
