I'm trying to replace a ceiling fan and am struggling to understand how to update the wiring inside the ceiling box.
- Both the old and the new ceiling fans include a light.
- The old fan accepted separate wires for the light and fan motor.
- The new fan only accepts a single wire that powers both the light and the fan motor.
- The room has a single wall switch that controlled the old fan light. To control the old fan motor, we used a pull chain that was directly on the fan.
Here's a diagram to illustrate:
common neutral
┌────────┬──────┐ white │ │ white ┌──────────┬────┐
│ cable 1 │ │ cable 2 │
└────────┴──────┘ black │ │ black └──────────┴────┘
│ cable 3 │ │ │ │
black │ │ │ │
│ to old fan motor
│ │ to old fan light
│ wall │ controls old fan light
│ switch │
If the diagram is unclear, here's a photo.
I'm trying to wire up the new fan, which only accepts a single hot wire. Overall power to the new fan is controlled by a simple wall switch, and a wireless remote is used to control the light intensity and fan speed.
The wall switch is presumably connected to cable 3, since it controls the light. But I don't know what to do with cables 1 and 2. Do I just use cable 3 by itself, and leave cables 1 and 2 in a state of holy matrimony, connected to each other and nothing else?
Also, can someone explain how power was flowing through the old fan? I don't get why the white wire from cable 3 was connected to the black wires from the other two cables. I assume it's because of how the light and fan motor are wired together inside of the old fan.
