My fridge is model RH25H5611SR/AA. When I search for that model number on SamsungParts.com, and then search for "cam" I see parts listed but they all have an "L" in their name. I'm guessing these are for the left door? My right door does not close, I want to replace the cam on that door.
The part it suggests that seems most-applicable is,
DA66-00696A CAM HINGE-RISER LOW L
Does that part work on both the left and right the door the unit is split door with one door for the fridge and one for the freezer. You can see the pictures at Lowes.com?
If it doesn't work on the right door, what mechanism is responsible for the left door not closing fully?
Here is what my parts actually look like
