I'm looking at installing some security cameras at my place. I have an outdoor outlet that is ideally positioned to power one of the security cameras, however, using a test to figure out if it was working, I noticed that the polarity is reversed.
It seems to be reversed at the outlet, but I tried pulling it out of the receptacle box a little bit to see and the old romex and the freezing temperatures outside make it very hard to work with and attempt to fix for the moment.
Doing some research, I learned that there is a potential danger for appliances with a power switch, because on could be off and vice versa. In my case though, all I need to plug in for the camera is a pretty standard 5v USB AC/DC power adapter. Is there any risk to humans or the cameras in this scenario?
... no, with reversed wiring, the power switch controls the neutral, which means that the appliance has hot connected at all times
