I am trying to mount my Tv and I am using a 1/2” piece of plywood to make it centered. The TV weighs 78 pounds and not 100% sure about the mount. The mount is a full tilt extension and extends up 5.2”
My question is, can I use a toggle bolt behind the piece of plywood and put the screw from the toggle through plywood to hold the TV bracket secure? I am currently planning on using a 3/4” round slotted screw to hold the bracket to the plywood. I just feel like it won’t be secure enough.
If the toggle idea is not a good solution, then what would be?
