Which way do you rotate vertical blinds during the winter? I wanted to keep the place warmer, and keep cold air out. Should the Curved edges of the vane
- Curved edges be turned towards you, facing away from the window?
- Curved edges be turned away from you, facing towards the window?
Or does it really matter?
This is for heat insulation.
