My impact driver is probably my most used tool for home DIY tasks. I have a corresponding set of bits that are very useful. Two of them, however, are a bit confusing to me:
They are double sided. If I place one end in the bit holder as shown in the bottom photo, it's very wobbly. How are these meant to be used?
Thanks!
  • Notice how all three of those bits have the same back end? That depression is designed to fit the tool's retainer. They're not intended to be stacked.
    Dec 7, 2021 at 20:38
Very simple: Don't put them in the bit holder.
The bit holder has two uses:
  • Allow use of short bits
    The double-ended bits are long enough that they don't need a holder.
  • Allow easy change of bits
    The double-ended bits each give you two bits in one. Loosen, flip, tighten.
You should make sure the bits are designed for impact drivers - some are, some are designed only for use in ordinary drill/drivers.
11
    Regarding the second part of what you said, I'm almost certain it's fine to use these in the impact mode (I don't think my impact driver has a non-impact mode). They came in a set clearly labelled "impact duty". Similar: homedepot.com/p/…
    – Dan
    Dec 6, 2021 at 23:39
  • I've never seen an "impact driver" that didn't have a non-impact mode. Using ordinary screwdriver bits in impact mode, even if technically OK, will wear them out faster and mess up the stuff you're working on too. Take a look on your tool for a switch (other than the power and forward/reverse switches). Dec 6, 2021 at 23:42
  • There's the forward/reverse/neither switch. 1,2,3 buttons for torque limiting and a special mode for driving self-drilling screws. Makes sense about not using regular bits in impact mode. As mentioned above, I think these ARE impact bits.
    – Dan
    Dec 6, 2021 at 23:44
    I have worked the heck out of a double ended bit with an impact driver. A #3 phillips bit. driving self drilling tapping 14ga screws through 3/4" plywood into 14ga metal by the hundreds. They really last, at least the brand I had They are not meant to be used with a bit holder....
    – Jack
    Dec 7, 2021 at 5:48
