shower drain with screws removed
As you can see, there is black mold growing inside the white pipe under this shower drain cover.
I've removed the 2 screws. The silver metal circular grate still feels stuck.
If I try to pry it out with a screwdriver, it feels like I'm going to bend and maybe destroy it.
Are these threaded and screwed-in somehow?
How can I remove it?
Alternatively, how could I do a thorough cleaning of the pipe without removing it? (I've already tried vinegar and baking soda, which had no effect.)
P.S. It says UPC® on one side, Made in USA, and SC (where the S and C are on either side of an dual-triangle hourglass shape).
    That type of drain cover is usually held in place with only the two screws. You can try turning it but screw-on covers generally don't have screws. Probably has some soap scum and calcification holding it. Gently pry it up and you can scrub the inside of the drain with a cleaner of your choice. A bleach solution is very effective against mold.
    – HoneyDo
    Dec 3, 2021 at 19:40
    The cover may have been embedded in silicone before being screwed down (severe overkill and a pain for future maintainers, as you've found - no other benefit). Or, it might have been mortared in place by the grout job. In either case, destruction could be the only option, but it's certainly not the first option.
    Dec 3, 2021 at 19:56
    bleach spray should knock that mold down, likely even w/o removal of the grate.
    – dandavis
    Dec 3, 2021 at 21:49
    Yeah - looking again, that may be silicone caulk around the edge. Run a blade around it and it should pry up.
    – HoneyDo
    Dec 3, 2021 at 22:00
    You all have been so helpful. Thanks for the blade suggestion, @gnicko! I'd accept your answer if you submit. What I did was run a razor around the perimeter, and I thought it was useless because it didn't seem to be getting in between the grate and the surrounding, and I don't think there was any silicone or anything there, but I noticed plastic or something accruing on the razor, so it was doing something. Then I used 1 screwdriver to pry from one of the square openings, and ...
    – Ryan
    Dec 3, 2021 at 23:07
Try running a very sharp knife or razor blade around the edge of the cover plate to help break the seal of what might be holding it. It looks like there's caulk or grout in there. I'm not sure you'll notice much of a change, but it could help get a hold under the edge and aid you in gently prying it up.
Then I used 1 screwdriver to pry from one of the square openings, and then I used a 2nd slim screwdriver to catch and pry as soon as I was able to get the grate the tiniest bit lifted (and then pry more using that 2nd one). Thanks!
