I’m about to replace some of the brass water pipes to PEX in my basement. I bought an adapter fitting at a plumbing supply store(picture 1) and cut the cold water pipe(picture 2). I tried to remove the pipe from the old fitting in order to install the adapter (picture 3). The problem is the pipe stuck in the fitting. I used heat gun to melt the glue down but it doesn’t work. I don’t know what kind of glue the plumbers used in 1947. It’s very strong. Please give me some advice.
enter image description here enter image description here enter image description here
    That's not "glue" it's "pipe dope". It's designed to waterproof the threads.
    Dec 3 '21 at 14:51
    Possibly a hardening product like a "Permatex". Dec 3 '21 at 16:15
I'm a plumber in Texas and we see that slot The old timers used linseed oil and cement to seal those joints. I won't even waste my time with pipe wrenches because you won't unscrew the pipe. Cut the pipe close to the fitting. With a sawzall and a small cutting blade. Notch the inside of the pipe in four places and chisel it out with a small screwdriver.
You need two pipe wrenches - one for the pipe and one for the fitting so you don’t damage the other pipes.
However, I would likely go with a solder fitting to get to what you want if that is so tight.
  • A little heat would probably soften the thread compound.
    Dec 3 '21 at 15:35
  • @isherwood OP mentions heat in the original post, but a louisiana spanner would probably provide more...
    – Solar Mike
    Dec 3 '21 at 15:43
    Thanks. Missed that. To clarify, a lot of heat, like what a plumber's torch would provide. The pipe itself need to be quite warm to the touch. I suspect that the heat gun wasn't adequately implemented.
    Dec 3 '21 at 15:46
  • @isherwood Couldn't a lot of heat affect adjacent joints and cause those joints to start leaking unless you could re-tighten them as well?
    – MonkeyZeus
    Dec 3 '21 at 18:44
  • I wouldn't think so unless they were rotated, breaking the bond. I have limited thread compound experience, though.
    Dec 3 '21 at 19:14
This looks like a crack in the T fitting:
Image of Fitting
If so you should replace it.
    True (though I think it's just a stain), but not an answer. Should've been a comment.
    Dec 3 '21 at 15:15
  • True, @isherwood, but it's hard to include an image in a comment. Though a link would do the trick.
    Dec 3 '21 at 15:32
  • No it's not (you can upload in an answer box if you like and copy the URL). And that's not an excuse to violate site rules.
    Dec 3 '21 at 15:33
    I believe it is an answer. If the fitting it cracked, then it should be replaced. That overrides the original problem of how to remove the fitting.
    – jwh20
    Dec 3 '21 at 15:48
    A person would still need to know how to replace it, which was the question. I don't think I'm being overly pedantic here.
    Dec 3 '21 at 15:54
