11
We just ordered a new Bosch dishwasher from Home Depot, including third-party installation. The installer they sent looked under the sink and said that because our stop valve is too old, that he could not do the installation "through the company". I said that I could hop over to the hardware store to get a new valve, but he would not allow me to do that. He said that he could do it off the books if I gave him $100.
Instead of accepting this offer, I rescheduled the installation for next week-- I will buy the $10 valve and put it on myself. However, I don't see what the problem is with the valve that we have (visible in the center of the picture). Is the type of valve that we have simply not used any more? If there is an issue, I'd like to fix it correctly before another installer comes.
Under the sink
12
  • 6
    maybe the tech wanted to make some extra cash .... i see no reason why the service would not be available "on the books" ... the only problem with those valves is that the rubber washer disintegrates after some years and pieces of rubber end up downstream ... get a 1/4 turn ball valve
    – jsotola
    Nov 27, 2021 at 2:12
  • 39
    On top of rescheduling, report the tech to HD.
    – r13
    Nov 27, 2021 at 2:59
  • 4
    Not valve related, but: the tech sent to install my new washing machine refused to do so because of an existing (~1 year old) water hose, then tried to sell me a replacement hose for ~100€ (5x retail price). I sent them home and did the installation myself, but I suppose not everyone is willing/able to do that. Nov 27, 2021 at 17:32
  • 10
    Did the installer attempt to turn off the valve and have the valve fail to actually turn off the water? Or, did they just look at it and say "no, can't do it"? If it's the former, then that valve does need to be replaced, which could easily be a larger job than what the installer is contracted for by Home Depot. If it's the latter (look, but no test), then you need to find out what's imposing that requirement. Is it Home Depot and the contract with the installer? Is it a code requirement in your area? Is it just the installer wanting some extra cash?
    – Makyen
    Nov 27, 2021 at 21:12
  • 6
    @TylerH - I expect it to be a contractual issue rather than a fraud issue. He's a third-party contracted by Home Depot to do straight dishwasher installations. In order to keep costs down, it's likely that Home Depot has limited the scope of his work (and any associated warranties and insurance) to simply "install the dishwasher". He's probably also not allowed to take on work from HD customers without going through them. So installing as a cash job is about the only way he can do it. $100 seems steep for a $12 part, but it probably covers time to go pick up the part, the part and install.
    – DWGKNZ
    Nov 29, 2021 at 15:16
5 Answers 5
23
Capsule summary of the comments:
  • Your old valve should probably be replaced with a new quarter turn ball valve version. Those old valves wear out and break your heart when it really matters.
  • Report the installer to Home Depot. There's a strange, outside chance that they are limited in what they are allowed to do, but I sincerely doubt it.
    "quarter turn" = ball valve. And yes, ball valves are better. Nov 27, 2021 at 5:45
  • 7
    Disagree. I think "including installation" does not include updating your plumbing. In fact, you're lucky if the gorillas they send out would know how to update your plumbing. I think OP is lucky the installer recognized the need and offered to do it and didn't just install the thing poorly in order to check the box and go home.
    – jay613
    Nov 27, 2021 at 15:08
  • 7
    Disagree with point 2. This is perfectly par for the course for Home Depot, they paid enough claims and lawsuits over water leaks. Another known example is Home Depot will not install any washing machine without brand new flex hoses.
    – user71659
    Nov 27, 2021 at 22:17
  • 4
    @user71659 What about "he could do it off the books if I gave him $100"? Is that worth reporting to HD?
    – nanoman
    Nov 28, 2021 at 4:30
10
You should update this valve now that you are in there installing a new dishwasher.
The dishwasher purchase, "with installation" correctly does not include updating your plumbing.
It is extremely easy to replace this valve yourself. The pipe is exposed and in good shape and the old valve uses a compression fitting. Buy a Sharkbite quarter turn dishwasher valve (straight, not 90 degrees) and a Sharkbite pipe reamer. Unscrew the old one, shove on the new one and you're done. 5 minutes.
If you want someone else to do it, I'd accept the offer from this guy. It's reasonable and you don't have to find someone else and coordinate.
10
  • 16
    Disagree. It's a jacked up price from a profiteering "installer" who "would do it "off the books."" And there's no need to faff about with a sharkbite where there's a perfectly good compression fitting on the pipe.
    Nov 27, 2021 at 16:15
  • 4
    Is it clear to all that the installer works for the appliance retailer not for OP? And probably is subject to a massively lawyered up contract designed mainly to protect that retailer?
    – jay613
    Nov 27, 2021 at 18:37
    The compression fitting is a bog standard part. You unscrew the nut from the old valve and remove it. The nut and ferrule already on the pipe screw into any compression fitting of the same size - you just remove the nut and (uncrimped) ferrule from the new one. You most certainly can re-use them, if you're not so daft as to try and remove them from the pipe they are installed on.
    Nov 27, 2021 at 18:42
  • 4
    for that one little task is likely to cost $100 when he walks through the door. So $100 is perfectly reasonable in comparison to that. A lot of people will not attempt a valve replacement themselves, and some others will decide that unless they enjoy trips to HD (I do, but well...) that the time it takes to get the part and install it is not worth it and they would rather just hand over an extra $100 and be done. Nov 27, 2021 at 23:41
    @manassehkatz-Moving2Codidact I take "off the books" to mean "without warranty and insurance", which should be included in the $100 you pay for the proper plumber. For me that would be one reason to avoid such an offer (the other reason being that where I live working "off the books" would be tax fraud). Nov 28, 2021 at 16:56
Let me take this from the value proposition angle (I am assuming you own none of these)
  • A scoring tube cutter is about $15.
  • A simple metal file is $10 or less (or you can buy a de-burr/reamer tool for more than that).
  • A Sharkbite 3/8" ball valve itself (just shove it on) is maybe $12 (and it's as close to goof-proof plumbing as you can get)
  • A water shutoff key is less than $10 in most cases
So about $50 in hardware. Takes about 10-15 mins to turn your water off, cut the pipe, deburr it, shove the Sharkbite on and turn the water back on. By the time you add all that up, the average homeowner is probably not going to spend that time and money when you can pay some guy who has it on his truck and all the tools to do it right there. Add in the convenience factor, and $100 isn't exactly unreasonable, but you could spend that money to have the tools yourself to replace, say, the other valve under your sink. Or the rest of the valves in your house. And you come out ahead from not paying the installer some $90 to do it. This is a DIY site and... well, we're gonna tell you to buy the tools and do it yourself.
The reason HD likely has a policy like that is these older mutli-turn stop valves do wear out over time. My house is some 40+ years old and I've been steadily doing this over time because some of them just stopped working properly (some needed a wrench to get them to cut off). I recently replaced my kitchen sink and the gaskets inside disintegrated when I tried to turn them off. It's worth your time to buy the tools and replace both valves there (and any others you can reach).
  • Why sharkbite? Why not just re-use the existing compression fitting?
    – Glen Yates
    Nov 29, 2021 at 17:25
  • @GlenYates The OP said their installer said it had to be a quarter-turn ball-valve or no deal. Possibly a scam, but there are legit reasons to balk at the crank-turns like this.
    – Machavity
    Nov 29, 2021 at 17:27
    I was questioning the recommendation to replace the valve with a sharkbite version, not questioning whether the valve should be replaced with quarter-turn ball valve - it should.
    – Glen Yates
    Nov 29, 2021 at 17:35
    Except in this instance, sharkbites are way more hassle! To use a sharkbite, you have to cut off the existing connection then file the cut smooth. To replace the old compression valve with a new quarter turn compression valve, you simply unscrew the old one and screw the new one in. You don't need any tools but a wrench.
    – Glen Yates
    Nov 29, 2021 at 18:40
    I suspect the people suggesting SharkBite fittings are used to sweated on shut off valves, as you correctly noted, in this case, they are compression fittings and no pipe cutting is needed to replace in kind (with the ball valve type).
    – DaveM
    Oct 17, 2022 at 0:45
I had the same issue with a Bosch dishwashwer. HD 3rd party installer told me the same thing, except that he wasn’t willing to do anything “off the books”.
The issue in MY case is that the thread on the existing valve is different from the “more modern” compression valves. While everything looks perfectly fine, the thread on the “water from the outside male connection” isn’t “a reduction thread” while the fitting on the dishwasher line from that fitting TO the dishwasher IS “reduction thread”.
I bought a new valve/fitting from Ace, will turn off the water and replace the existing valve with the new one, which SHOULD allow the dishwasher line to connect without me having to jump through hoops otherwise.
It is a modern income source for Home Depot and other vendors. I recently purchased a washer and dryer from Home Depot and they would not install them without all new connection equipment ( hoses, wire, ducts, etc). You could consider it profit or covering the cost of install labor. Not all a bad idea as I can imagine some of the equipment is old and worth updating. I had previously installed all my own stuff including furnaces, roofing and central AC , but I am older and tired now, so not a bad deal.
