I was in the process of removing a keyless chuck on a cordless drill. I removed the screw from the chuck first and for some unknown reason managed to close the teeth on the chuck without inserting an allen wrench and they're now stuck. Tried everything to open them to get the allen in there but nothing has worked so far. What can I do to get this thing removed?
    It's very difficult to follow your question. Please consider adding a photo and a better explanation of what you are trying to do.
    – jwh20
    Nov 25, 2021 at 10:58
    Pic of the chuck, please. Nov 25, 2021 at 17:24
  • I managed to remove it with vice grips and a hammer. This is after it was removed: imgur.com/a/Me635tc
    – Sam R.
    Nov 26, 2021 at 7:00
I wasn't able to open up the teeth so ended up using vice grips on the chuck itself. A few good whacks with a hammer to loosen it and used the drill's power to unthread the rest of the way.
If you have jammed it shut then a cutting disc in a grinder may be the best solution.
Take care not to damage the threads or spindle.
