The door to my new apartment has a large gap that allows cold air to flow in
What is the best, simplest and most effective way to plug this gap?
door gap to floor
  • What's on the the other side? The outside or a hallway?
    – P2000
    Nov 25 at 14:57
  • On the other side of the door is the raw elements Nov 25 at 23:18
Use a brush seal
This will significantly reduce the air leakage, but also prevents the floor from being damaged if there are objects in the way.
If the floor is not prone to damage, you can use more solid material.
  • Perhaps OP should also confirm that the opening is not required for HVAC. Some apartment buildings heat/cool with pressurized hallways.
    – P2000
    Nov 25 at 14:56
  • @P2000 good point. It's not Nov 25 at 23:18
On my front door I used this product:
self-stick weatherstrip
It can be straightened out to a flat strip, and has stayed put for many years.
On my side door I used this:
garage door weatherstrip
with the top and bottom edges cut off. My doors are dark colored, I hope you can find something in white.
