The gap is 1-8mm wide. The window sill is PVC thus probably only selected glues will work. Wall is drywall. This is a low window sill on a high window - so in the right lower corner you see the covered room floor. The sill is just 15cm above floor level.
Edit: talking about gap on the right (Yellow is membrane not yet cut to fit)
Options I was thinking about:
- fill up with silicone or acryl and level it to the window sill (2K epoxy will not work as the sill is hallow, then I would need to fill up the whole sill, 2K epoxy putty would work)
- make a silicone joint with a falling angle from the wall (better than leveled to the sill?)
- glue some flexible profile - would still get a bent line which would propably catch the eye
- tape it with a durable white tape - (probably not)
(leveling the wall is not an option - too much effort)
Maybe there is some creative idea out there. Else I tend towards the silicone fill + leveling to the sill.
