I'm upgrading to a smart thermostat, which requires a C wire. My current thermostat cable has 4 wires, no C wire. The controller in the furnace does have a C connection. The system has both heat and AC.
So, I could replace the cable with a 5-wire cable, and all would be good. It runs through the crawl space, so it's accessible, but I'd rather not have to spend all that time on my knees and belly. I'll do it if there's no good alternative.
The thermostat is a Honeywell T9, and it comes with a C-wire adapter for this kind of situation. 5 wires go to the furnace controller, and 4 go to the thermostat. There's an installation manual that explains in great detail how to install the adapter.
The superficial explanation I've seen about what this adapter does is that it combines the G and Y wires, and calls the combination K. So, if I understand that correctly, there's a single wire, the K wire, that controls the AC and the fan. I can see how the adapter could have some internal logic to recognize that both K and R are active, and turn on the heat and the fan and not the AC.
We run the fan full time; the house needs that circulation. Does that K wire mean that I lose manual fan control? The new thermostat also can run the fan at random times; would I lose the ability to do that?
