Cat scratches on varnished wooden door: tried rubbing walnuts, only hides the smallest scratches not the big ones.
Is there any paint or varnish I could use in an attempt to cover this mess?
Sign up to join this communityCat scratches on varnished wooden door: tried rubbing walnuts, only hides the smallest scratches not the big ones.
There are a few options available to you. You can try a walnut putty stick from your home store to fill i the larger cracks. For plain surface scratches, there are walnut stains that you can blend in. You can then dab on some varnish to finish it off. It will take a little experimenting to get it just right.
Eraser.
If you are referring to that wavy, vaguely sinusoidal horizontal line that is not cat. That is kid, and it looks like pencil to me. Try a pencil eraser.
And even better than you trying a pencil eraser, ask kid about the line and then ask kid to erase it. Grampa used to say "him what messes up cleans up".
