I am trying to hook up a new flush mount LED light fixture in my basement. The existing metal box has the ground wire screwed into it, so there is only a loose white and black wire. The light fixture has a green ground wire. There is no bracket for the metal outlet box and one is not required with the light fixture I'm putting in.
So what do I attach the light fixture ground wire to?
  • Can you post a photo looking into the back of the box please? Nov 22, 2021 at 5:28
  • Not the actual picture of my metal outlet box, but same idea. Feeder ground is hooked around screw in metal outlet.
    – GailO
    Nov 23, 2021 at 2:04
  • Can you not get us a photo of the actual box in question? Nov 23, 2021 at 3:00
