I'm working on refinishing my basement and I want to turn one of the downstairs rooms into an office. I need to add a door to close off the room which happens to be entered from the bottom of the basement stairs. The problem is I don't have enough room at the bottom of the stairs to fit a standard width door, I only have about 26" from the last stair. Here's what I've thought of so far:
  • Build the door back into the room a bit
  • Angle the door
  • Install a pocket door that runs along the stairs (downside here is the width would only be like 26" which is less than the 30" code in my state (MA).
I've attached a diagram showing what I'm considering and some pictures of the space. I'm open to other ideas if anyone has one! Thank you!
Option 1
Option 2
Room View 1
Room View 2
  • can you get by with an accordion pull-out door like used for utility closets?
    – dandavis
    Nov 16, 2021 at 18:06
