I'm currently in the process of insulating/drywalling my attached garage. It is about 25' x 20' with Fink style trusses. The truss bottom chords are spliced with plywood sheets on either side. Rather than metal plates to attach web members to chords, there is plywood sandwiched on either side, since this house was built in the early 70s, I assume this is time of install appropriate?
The trusses run perpendicular to the garage door and there is a center beam installed over the bottom chords of each truss spanning the entire garage from wall to wall running in parallel to the garage door. My question comes in here... this center "beam" is just two 12' 2x4's overlapped, and I'm noticing the center of the trusses sagging.
To my understanding, a truss should not sag like this (obviously). My only thought is the splice is weakening in the trusses or excessive weight was in the attic space at some point. I'm assuming this makeshift beam was added after by a previous homeowner to try to put more storage in this attic space...
Either way, I would like to essentially replace the 2x4 "beam" solution with 2-ply 1-3/4" x 7-1/4" LVL 22' beams and then tie in the bottom chords of the trusses with some sort of strongtie with multiple beefy nails rather than just the toenail approach they used originally.
I've attached a picture of the construction and a close-up image of where the bottom chords are separating from this beam. Additionally, its shown that this beam is not resting on either wall at all and has no support on either end essentially making this whole thing useless.
So in summary, my thought is beef up the top plates on either wall where the beam will sit atop to make up the gap shown in image (since bottom chords sit on top of the top plate). Then sandwich together 2 of these 1-3/4" x 7-1/4" 22' LVL beams together to stretch the span and take the sag out of the bottom chords so I can insulate and drywall. I'd probably avoid putting much, if any storage up there in the future since it clearly wasn't designed with that in mind. I know the depth/width of the beam for this span would normally be much bigger if it weren't for the trusses, but since there are trusses taking most of the load, I feel like this beam doesn't have to be all that large. My goal here is to ensure this isn't going to worsen when I install insulation and drywall and possibly be able to store light weight holiday decor in the attic space since I don't have a basement (crawlspace).
Overall construction with makeshift beam
Bottom chord separating from makeshift beam
Beam does not rest on top plate of either wall
    If I see the "beam" you are referring to, that is just a part of the truss system to keep the bottom chords straight, so they don't sway or buckle when the roof takes on a load. It is not there to add any structure for storage on the bottom cords. Many if not all simple truss configurations do not allow any kind of storage at all, although many times it is used for light storage regardless.
    – Jack
    Nov 10, 2021 at 5:20
    There appear to be multiple hooks with loads suspended from them attached to the bottom chords. Those are probably a bad idea with this structure. The center 2x4 is not intended to carry any loading, it's simply to keep the trusses correctly spaced.
    Nov 10, 2021 at 13:56
  • Yes, I agree with what you're saying. The "loads" suspended from those hooks right now are very small, lightweight items just to free up space while I was doing drywall/insulation. The garage is chaos because we just moved in a few months ago. However, to your point, I think at some time, there was excessive weight hanging on or put on top of the chords which may have caused this in the first place. I plan to remove all weight from attic space besides the garage door motor being mounted obviously. My proposed idea is really only to bring the chords back straight to install drywall.
    – seggles
    Nov 10, 2021 at 17:07
In a typical roof truss design as you are showing, the bottom chord is under TENSION not compression. So any sagging is coming from some other factor than the roof load.
The 2x4 "beam" that you have is NOT carrying the roof load or any other load for that matter. It's not clear why that was added to the structure other than to add some rigidity along the truss bottom chords.
As far as the sagging itself, it's hard to tell from the photos but it could be that something is applying a compression load to the walls and causing the bottom chord(s) to bow. It's not clear that only the one of these is bowed or others as well. Perhaps the wood has just warped over time.
Before you go making significant structural changes in the blind, you will do well to consult a structural engineer to inspect and analyze what's going on here and make specific recommendations to accomplish your goals for the structure. You're likely going to need that anyway before your plans will be approved and issued a building permit.
  • Yeah, totally agree with everything you're saying here. I don't have any reason to believe the walls are causing compression.. but not an expert. I'm really leaning towards a previous homeowner just storing entirely too much weight up there. For example, there's an entire box of hardwood flooring up there right now. I plan to remove all storage from this space. As for my beam idea, it was only ever to bring the chords back up into place to allow for drywall to be flat when installed. However, I have reached out to a structural engineer for a professional opinion.
    – seggles
    Nov 10, 2021 at 17:09
