I have a stream of water going under my siding from the gutters. The gutters are new and completely clean, no debris. Also, the roof has vented drip edge extending into the gutters about an inch.
I can't see the water rolling over my gutter in the attached video. What should I do to remediate this issue? The water is getting behind my siding and causing damage to my bay window that is underneath. Video of water stream
    Did you see this question: diy.stackexchange.com/questions/18701/…?
    – gnicko
    Commented Nov 10, 2021 at 13:33
    diy.stackexchange.com/questions/170876/…
    – gnicko
    Commented Nov 10, 2021 at 13:42
    diy.stackexchange.com/questions/181733/…
    – gnicko
  • Thanks everyone, however this does no address my issue. I had a adjuster review installation, drip edge and gutter at fault(installer says not his fault). airvent.com/index.php/products/intake-vents/vented-drip-edge. Vented Drip edge installation guidance there. If there is a way for water to wick its easy over all the drip edge vents, the final piece of the drip edge is tucked behind the gutter, as recommended in their installation instructions (why, im not sure). How do I tell if the water is going over the gutter or between the gutter and fascia?
    – BJake
    Commented Nov 11, 2021 at 4:41
  • Are you sure that water is getting behind the siding or is the water entering around the window trim? Looking at the video it doesn't seem likely that the water is going behind the gutter.
    – gnicko
    Commented Nov 11, 2021 at 16:26
Somebody definitely made a big install mistake there... No quick fix for that it has to be all disassembled and put back together the proper way
  • But what is "the proper way"?
    – Simon B
    Commented Nov 18, 2021 at 20:59
