How do I identify what kind of hardwood flooring this is by the grain?
1that is not walnut and almost surely oak. Walnut grains are way way more subtle and wavy.– DMooreCommented Nov 8, 2021 at 17:00
199% certain that's oak. Are you doing a patch job or a repair? If so then you'll need to figure out whether it's red or white oak.– MonkeyZeusCommented Nov 8, 2021 at 18:08
Something to think about: Identifying wood from a picture is difficult enough that it's considered off-topic at Woodworking.– FreeManCommented Nov 8, 2021 at 18:18
For what it’s worth, the diagonal ray fleck is classic quartersawn oak. (Ray fleck occurs in other species, though usually to a lesser degree.)– Aloysius DefenestrateCommented Nov 9, 2021 at 23:29
Add a comment
1 Answer
Oak - more lines (harsh), texture, example
Walnut - several species are used but the have more of a wavy, "rock hit water" texture.
Black walnut
Traditional American
For solid hardwood, oak is by far the most common in the US. Engineered hardwood has more variety since only a sliver of wood is needed - many more varieties become affordable.– JPhi1618Commented Nov 8, 2021 at 17:20
