I'm emigrating from the UK to the US. I had assumed that both my Blendtec blender and KitchenAid mixer would not work well in the US not least because the higher mains frequency would make them spin faster and cause overheating.
However I've just noticed both appliances say "50/60Hz" and "220-240V" on the name plate. From what I've read, it's possible and legal to have an electrician install a 240V NEMA 14 receptacle from the two 120V feeds.
Does this mean I could theoretically use these appliances in the US?
Is there anything else to consider e.g. efficiency, fuses, codes, etc? Locality would be Philadelphia, likely a rowhouse.
Perhaps the real question is: even if I can, would you say that I should? E.g. it might cost hundreds and/or have questionable legality or horrible efficiency.
Oddly the US KitchenAid is actually higher power (325W vs 300W).
Bonus points of keeping them are that they were wedding gifts and I'd be able to plug in a decent kettle if I had a 240V receptacle! We're sending a part container load anyway so it's not like we'd be paying to mail them.
13
    Are you purchasing or renting? If renting, you’d need to get approval, but the newly added 240v receptacle could be turned into 120v, so it needn’t be a permanent change for any future residents. You would need to have a circuit added from the breaker panel. Nema 14 is very large. A nema 6-15R or 6-20R (15 or 20 amp) would be the common size.
    – Tim B
    Commented Nov 2, 2021 at 23:10
  • @TimB I'd be purchasing. Thanks for the info!
    – sjmeverett
    Commented Nov 2, 2021 at 23:18
  • Good Question - I'd consider changing the title though. Commented Nov 2, 2021 at 23:58
  • 4
    In my upcoming kitchen reno I'm planning to install at least 1 240V outlet just to be able to plug in a decent kettle ... ;) The puny little 120V ones typically available over here take for ever to boil.
    – brhans
    Commented Nov 3, 2021 at 0:50
  • @ChrisCudmore thanks, what do you suggest?
    – sjmeverett
    Commented Nov 3, 2021 at 1:10
You should be able to do this, but there are a few things to consider:
  • Any 240V receptacles should be in addition to the required 120V receptacles. In a kitchen you need at least 2 counter-top circuits and a receptacle every 4 feet (there are some exceptions).
  • An MWBC (2 x 120V on a matched pair of breakers) can power both a 240V and a pair of 120V receptacles. Alternatively, you could run a separate 240V-only circuit. But you can't simply "take 2 120V and pair them" - for a bunch of reasons including GFCI.
  • Any regular kitchen circuits (as opposed to oven) need GFCI. For 240V that will normally mean at the breaker, not at the receptacle.
  • Plugs and cords need to match. So either you install a standard NEMA 6-15 or NEMA 6-20 (US 240V circuit standard receptacles) and change the plug on the appliance, or you install a UK-standard socket and use the appliances as-is. I'd recommend NEMA 6-15 or NEMA 6-20 sockets, as that keeps the physical installation standard (so no problem from inspector, standard UL-listed parts, etc.).
    Great, thanks for all the detail! The point about pairing the two 120V lines was recognising that you apparently usually have two 120V feeds to the property on opposite sides of neutral, making 240V surprisingly (to me) possible — I realise you do need a new circuit. We usually only have a single 240V feed plus neutral here (and sometimes earth). I didn't realise it would be legal to install a UK socket, so I had assumed a NEMA 6 would be the way to go. Even if it is legal would probably prefer to be standard anyway, as you say. Thanks!
    – sjmeverett
    Commented Nov 3, 2021 at 16:31
  • 4
    If you own the house and you install a NEMA socket you can leave it there when you sell. It's easy to change the plug. This is a good answer, I'll just add that 1) good on you for checking 50/60Hz and 2) I would only do this if the appliances are high-end ones. $250+ each. Which I believe they are. It's worth it. If they are cheap appliances, sell or store them and buy new ones here.
    – jay613
    Commented Nov 3, 2021 at 17:07
    Not that you asked but a much cheaper solution is to buy a 500W step up table top transformer, about $50. You don't have to cut holes in walls or cut plugs off your appliances. Sooner or later you'll either move back or buy American appliances.
    – jay613
    Commented Nov 3, 2021 at 17:10
    @manassehkatz-Moving2Codidact the Question is about a mixer and a blender. But true, OP also sees using a "decent" kettle, and no decent Brit who would call a 500W kettle "decent". OTOH, if he does not already own a $250 kettle my advice would still be to use the transformer, and buy a kettle here.
    – jay613
    Commented Nov 3, 2021 at 18:05
    Note that if you are installing UK outlets, the boxes are NOT the same size as standard North American boxes.
    – Nelson
    Commented Nov 4, 2021 at 2:48
Not a problem. We have outlets for that :)
You may have heard of the outlandish number of receptacle types that we Americans have. That's because your 240V 1-of-3-phase is basically equivalent to our 277V/480V industrial power, so it accomplishes everything you need "in one". But we have many sockets because of many ways to get 120V from 1- or 3-phase power.
And each type has 6 sizes (15, 20, 30, 50, 60 amp) because we are sticklers on matching socket size to supply size, and 2 types because some people want locking connectors. So here are the ones of interest to you.
The ubiquitous USA socket is to the left, of course. The right two are the two 240V variants you're looking for. Isn't that clever, how they're the same form-factor, with a twist?
These are NEMA 6 type, which delete the center neutral which your appliance has no use for.
The circuit rules
Firstly, the 125% rule: an appliance's plug must be sized for 125% of amp draw. So 0-12A uses a 15A socket. 12-16A uses a 20A socket.
As for the socket wiring, this is a surprise to most Americans, but these 240V circuits have the same rules as 120V circuits.
  • No limit to the number of receptacles on a circuit. (some localities limit to 8 or 12 receptacles, but the pictured receptacles have 2 sockets each).
  • 15A receptacles are allowed on 20A circuits.
  • 20A receptacles are keyed to accept 15A plugs.
  • However the rule requiring 20A circuits serving kitchen receptacles does not apply to 240V circuits.
By the way, the 240V ones in the photo have funny wires on the mounting screw holes. They can pick up earth from the mounting screws, if they go into a metal junction box - since incoming cables must earth to the junction box. Better 120V sockets have this feature also.
The USA requires junction boxes inside the wall for all electrical connections, because our walls are not stone. However our boxes are often plastic. For every reason we use junction boxes, metal boxes are superior. Plastic boxes are only cheaper.
There's a minor glitch with this, but given British love of earthing I don't see it as a problem: USA 240V power is like UK construction site power, both conductors are live with earth in the middle. Britain's requirement for earth means every single electrical device is polarized (neutral is known). That differs from Europe proper, where the sockets are flippable and you never know which leg will be live. It's possible a builder of a UK-only appliance might take shortcuts and not insulate the neutral wire very well. That would be a problem here (or in Europe). But like I say, not likely if they sell the appliance in Europe.
  • Maybe the mfgr of the UK appliance would have available a power converter to allow its use in the US with a polarized 120 V receptacle on a 20 A circuit. Of course, this would limit the output to 2400 W, 10 A at 240 V. Could he use a 120 V to 240 V step up transformer? If so, would or could one side of the output be neutral, i.e., polarized? Are there UL approved devices to allow UK appliances to be used in North America, at least ones rated for 60 hz? Commented Nov 3, 2021 at 20:58
  • 4
    @JimStewart the problem is our slow kettles. UK/EU heating appliances are not limited to 1500W. It's no problem for them to run 2500W (which isn't even 10.5A in the UK). There is no way to make an adapter which gets 2500W out of a US 120V plug. Certainly not after you apply our 125% derate, giving 3125W. At that point the only game in town is a 3600W+ 240V circuit. Commented Nov 3, 2021 at 21:12
  • When the standard supply is 240v, your heating appliances are significantly more powerful. I have a 6000W (on a 30A circuit) tank style water heater and it heats up water so fast it is effectively an instant water heater when I use it with my low-flow showerheads. I've tested it by making sure the tank is completely cold, turn on the water heater, and have the water slowly get hotter as it is being used.
    – Nelson
    Commented Nov 4, 2021 at 2:51
  • @Nelson electric tank water heaters are very well insulated and so what you thought was cold water inside might have still been warm enough to be useable for showering. Also, what is the temp of the input water to the tank? Where is this? "Electric shower heads" are used In some (tropical) countries. I would bet these are less than 6 kW, but this would probably not be powerful enough if the input water is cold. Commented Nov 4, 2021 at 11:44
    @jay613 Very close. Your only error is that kitchen MWBCs require a GFCI at every receptacle (if they don't have a breaker), so you need to credit yourself back $20 for every such GFCI receptacle that you eliminate by having a GFCI breaker. And yes, you can't eliminate any of the required "within 24" of any usable space on the countertop" 120V outlets, but if a whole MWBC comes to an outlet, you can spur off the outlet e.g. with surface conduit. Commented Nov 5, 2021 at 20:22
If your kitchen outlets are wired as multi-wire branch circuits (MWBC), where the top and bottom outlets of each duplex receptacle are on different circuits, adding a 240 volt receptacle is extremely easy and only requires swapping out the receptacle and doesn't require any wiring or breaker changes.
The good news is that this is a fairly common configuration in older kitchens that predate GFCI requirements (because GFCI receptacles make this configuration more difficult), and it's really easy to tell if your receptacles are wired this way. All you need to do is take off the faceplate and check the right-hand (hot) side of the receptacle to see if the breakaway tab connecting the two receptacles is broken off and that there are two wires (usually red and black) connected to the screws.
These two wires should be each 120v half of your 240v split-phase service. Any one phase to neutral results in 120v, but put the two together without a neutral and you get 240v again. You should measure the voltage across the two hot wires to confirm before proceeding. This works because MWBCs already use double breakers across both phases, so instead of connecting to one of the hot wires and the neutral, you connect to both hot wires. Since you have both hot wires in the box, it's a simple job to swap out the receptacle with a 240v version. MWBCs already use a double breaker, so it's perfectly safe and code compliant to do this if your double breaker has common trip functionality (meaning that tripping one leg of the circuit will also trip the other; this is different from tied handles, which is only for maintenance safety).
If your existing receptacles are the standard 15 Amp type with two vertical slots, you would install a 240v 15A receptacle (6-15R), where both hot slots are horizontal, and install the corresponding 6-15P male plug on your 240v kettle.
6-15R duplex receptacle
6-15P male plug
If your existing outlets are 20A, you could alternatively install a 240v 20A receptacle (6-20R), where the right slot is horizontal and the left slot is vertical, and the corresponding mirror image 6-20P male plug on the kettle. (20A receptacles also accept 15A plugs, hence the T-shaped slots.)
6-20R duplex receptacle
6-20P male plug
These parts are commonly available at hardware stores, and the receptacles are available in single and duplex versions.
What is not commonly available in stores but can easily be ordered online is a combo 120v and 240v duplex receptacle, so that you don't lose both of your 120v receptacles, and so you can also satisfy code requirements of having receptacles a minimum distance apart. These combo outlets are available in different versions, either as 15A (5-15R/6-15R, pictured) or 20A (5-20R/6-20R).
5-15R/6-15R duplex receptacle
GFCI
This doesn't cover GFCI protection though. I don't think 240v receptacles in kitchens generally need to be GFCI-protected by code (not verified), but if your kitchen isn't currently GFCI-protected I would either install a double GFCI breaker (if you can find one), or not worry about it. GFCI receptacles won't work with 240v unless the 240v receptacle is upstream of the GFCI devices.
  • Thanks, good info. It has been a while since I looked at it, GFCI might be required now on 240V, but either way it's a good idea for safety. AFCI is not required on 240V, but is required on 120V outlets in pretty much every room these days. You can get a double GFCI breaker, wire that to the 240V outlet, split into two branches from there, and put a 120V AFCI receptacle at the start of each branch which will also protect any 120V receptacles downstream — and you should, as far as I know, be all good with code.
    – sjmeverett
    Commented Nov 29, 2023 at 20:25
  • Another note: rather than change the plug on the devices, it's arguably easier to just use a NEMA 6-15 to UK adapter and keep the original UK appliance plugs.
    – sjmeverett
    Commented Nov 29, 2023 at 20:30
