I am about to install 5 gate hinges along the 14 foot long edged between two boards. I'm concerned that there will be a misalignment so that the hinges don't operate smoothly. Before I start trial and error fitting, can someone offer a best practices method for getting a good alignment in a case like this?
I thought I would start with the two hinges at each end and then, testing the operation as I go, work my way to the middle with the other hinges, but I still feel like there is more trial and error to this than there should be.
