I’ve been trying to remove a newer schlage lever style bathroom door knob for the past hour without success. Both knobs came off after pressing a pin in the small hole on the side of each knob. How is the rest of the latch mechanism removed? I tried pushing, pulling and turning but nothing has worked.enter image description here
Bingo! The rose was press-fitted on the hidden plate with the two screws. It was easily pried off with a small flat head screwdriver as described by “that it guy” who included the Schlage instructions. Thanks!
    Odds are really good that the escutcheon plate (the round trim ring) has to come off first. It appears that there's a little hole at the very top of your pic, almost cut off from the pic, that probably has a similar "push here to release" function. After that's off, removal may become more obvious.
    Commented Oct 27, 2021 at 13:00
  • I'm really glad you got this resolved! If you'll spend a moment taking the tour, though, you'll see that editing "thanks!" into your post isn't the appropriate way to say thanks around here. Clicking the up vote arrow next to every answer that helped you and clicking the check mark next to the answer that helped you the most is the appropriate action. It helps folks here who answer questions to know that this has an accepted answer, and it helps other people looking for answers to know that there's one here that solved it for someone else
    Commented Oct 28, 2021 at 12:25
The ring flat on the door is called the "rose". The one on the "inside" side of the door typically conceals the screws. (That's the side with the lock tab/button, or for entrance levers the side that doesn't have the key.) It's usually press-fitted onto a component screwed in place. It looks like there is a small slot near the top of your picture. Use a small flat screwdriver or similar tool and carefully pry that away from the door. (It shouldn't be on very tight; be careful you don't scratch or dent the door or the lock if you intend to reuse it.)
I found Schlage's installation instructions for the typical residential levers and knobs:
https://www.schlage.com/content/dam/sch-us/documents/pdf/installation-manuals/P515-445-sh2-c.pdf
There should be a small slot in the cover plate shown in your picture. It can be removed with a small screwdriver by twisting the screwdriver in the slot. That will expose a mounting bracket with screws than can be removed and the latch mech. can then be pulled out.
