I have a pair of internal doors that have somehow been installed incorrectly.
The doors are too tight against the stops and this prevents them from closing all the way.
The options I see to fix this are:
- Remove and rehang the doors, moving the screws just a couple of mm away from the stop. I'm not sure how to tackle this, I assume the screw holes would be refilled somehow and drilled with new holes just offset from where the original ones were.
- Shave some wood off the stop. This seems easier but I'm not sure of the best approach. I could sand by hand, use a belt sander, some type of plane. Not sure.
Any guidance from people more experienced with doors would be greatly appreciated.
Thanks in advance.
