I have a Lutron RadioRA2 keypad that needs power and I want to put it where I currently have a switch for an outlet. I swapped it in and it works if I have a load attached to the outlet. In my case a fan not turned on.
I want to de-hack this. Outlet is 1/2 switched, 1/2 always on. In picture below, top is not switched: black/white. Bottom switched: red/white.
Can I achieve what I want? I can get new outlet, keep tabs.
Would I:
  • Connect black/white to new outlet
  • Pigtial whites (neutral) together
  • Pigtail red solo
    That is correct. (with unbroken tabs) Write it up (the bit after "would I:") as an answer (yes you can do that here...)
    Commented Oct 23, 2021 at 23:30
    Other than this outlet, is there any other light in this room? Will it be controlled with a switch? (Doesn't need to be this switch). Commented Oct 24, 2021 at 0:11
  • There is an 3/1 circuit for ceiling fan I converted to 2 zone lighting via 2 dimmers. That is working well.
    – t9mike
    Commented Oct 24, 2021 at 15:27
So my real issue was I had my Lutron keypad wired wrong. It needs hot+neutral and I had hot1 (unswitched)/hot2(switched) from switched outlet to keypad. Changing to hot1(unswitched) and neutral in my wallbox has me up and running.🤦🏻‍♂️
  • Be happy that 2 hots didn't fry it!
    Commented Oct 25, 2021 at 15:39
  • I know! Lutron stuff is so good.
    – t9mike
    Commented Oct 25, 2021 at 16:53
