I have an LED panel in my bathroom which plugs into a small box labeled LED driver: input 85-265VAC, output 75-120VDC which is wired directly to the mains.
When I switch the light on, if it's been off for a long while it will flicker rapidly for a few minutes until eventually it goes on properly.
This light does not have a dimmer switch (I read that that can be the cause of issues like this). I'm not sure if the problem would be fixed by replacing the LED driver, or if I'd have to replace the actual light panel, or if the problem is in the wiring of the house.
Does anyone know what the problem might be, and if possible, how I can fix it?
Edit: I just noticed the LED driver makes a constant pretty quiet chirping sound, kind of like a quiet cricket
