I am installing ring camera outdoor flood lights. These devices are meant to be always powered. However, like many motion lights if you quickly turn them off and then on again their lights come on regardless of motion.
Rather than hope that my family and guests remember to "always keep the switch on" I'm wondering if I can have the opposite of a momentary switch.
That is, I want it always on but when pressed it's momentarily disconnected.
This should allow the devices to work as intended but also prevent people from accidentally leaving the switch off.
Edit: I wonder if I could do this with a normal 3-way switch. Connect the same load to both poles. Then it's always on but will be momentarily disconnected when toggling it?
ON-(OFF)
