I have an area that is designated to be an outdoor kitchen along our cinder block fence. The length is 15.5 feet and the height will be a little shorter than 8ft. The wall itself is nearly 6ft. So I'm adding less than 2ft to where I'm placing this wall. It will have hardy backer board on our side that will be tiled and then a countertop with sink and outdoor stovetop.
My question is, what are the best fasteners to use to attach the pressure treated lumber to the cinderblock wall? Would I be using a cleat for a 2x4 stud to attach perpendicularly to run of the cinder block wall?
I know there will be some of you who will say this isn't legal or up to code. So I'm just putting this out here now that I am doing this, regardless. Please just tell me what will be the most secure way to fasten 2x4 exterior grade pressure treated lumber to a cinder block wall.
Edit:
I'm adding some photos to help get my point across.
Notice the exposed cinderblock wall. That's the area I want to build my kitchen wall. The privacy panel on either side that's in a tannish brown is 8ft tall. I created that from fabric shade and am very happy with the results. I want to basically frame a wall that is made of pressure treated lumber and then attach it to the cinderblock. I want the height of my wall to be the same as the privacy panels I made for a seamless look (in terms of height). There will be cabinets at the base with a countertop, sink and stove top that will sit on the concrete platform at the foot of the wall. The height of the wall is just to match the privacy panels I made. I will install hardiebacker board on my side and then I will tile the wall from the height of the countertop up to the top of the wall. On the back side I will attach some plywood and/or some type of siding and paint it so that it looks reasonably nice for my neighbors. Does this help explain what I'm trying to do?
  • So... you want to put an 8' wooden wall up against a 6' cinder block wall?
    – gnicko
    Oct 15, 2021 at 0:27
  • Would be concern on how solid a cinder block fence is. Is it on a proper footing?
    Oct 15, 2021 at 0:28
  • This is kind of confusing. Can you draw this out or take a couple pictures?
    – DMoore
    Oct 15, 2021 at 3:05
  • I added some photos and more details in my original post. Hopefully the additions will help get my point across more clearly and without any confusion.
    – Adrien
    Oct 15, 2021 at 9:19
  • I hope your neighbor is OK with having no view out those windows anymore.
    Nov 14, 2021 at 16:18
Notwithstanding questions about the construction of the cinderblock wall and its suitability to support an attached wall or the wisdom of a cementboard/tiled wall extending beyond the cinder block wall, moisture/weathering concerns, aesthetics, etc. there are several methods for attaching boards to cinder blocks that could be useful for you. (I'll leave the other topics for someone else to discuss.)
For doing this you'll need a hammer drill and properly sized masonry bits. You could use "regular" drill and bits, but that's likely to burn up your bits and maybe your drill.
Screws:
This is probably the the most straightforward approach and the one I prefer.
Essentially, you're going to drive a screw through your 2x4 anchor board into the block. The holding power depends on the quality/integrity of the block itself, the quality of the screws, and having the right size hole pre-drilled.
One popular brand of screws is Tapcon but there are others on the market. What you need to do is drill a precisely sized hole The package should tell you what size bit to use (and some packages include the proper bit along with a handful of screws.)
Image swiped via Google Image Search
What you do is position the 2x4 where you want it and drill through the board, into the block, to the necessary depth. Remove the dust from the hole and drive the screw home to fasten the board to the block wall.
I recommend using screws with hex heads or at least star drive heads. The Phillips/slotted style screw heads will slip off and break bits, etc. Different diameter/length screws will hold with different degrees of force. I don't know the details of your project, so you'll have to figure out how many screws to use and so forth. Err on the side of too many.
If you're working with the hollow parts of a cinder block or the solid parts the screws will work, but sometimes they can cause old or low quality blocks to crack. Also, repeatedly removing the screws or over-tightening them can cause the threads to lose purchase on the holes and result in a loose/failed attachment.
Compression Anchors:
In this case a "plug" material--generally metal, but also plastic or even wood--is placed in the drilled hole and expands when a screw (or other fastening mechanism) is introduced to force the plug outward against the sides of the hole.
There are a lot of configurations of this and products sold by multiple manufacturers that range from light to extremely heavy-duty. The "classic" method was for a worker to drill a hole and insert a piece of wooden dowel into the hole to receive a screw. The screw would expand the dowel as it was driven in, and wedge the dowel against the sides of the hole to anchor the screw. Definitely "old-school" but I had shelves in my basement that were hung with screws into dowels for about 100 years until they were removed.
These anchors are inserted into a hole that goes through the object being attached and then into a hole in the block. The "pin" is then struck with a hammer to expand the end of the anchor that's buried in the block causing the anchor to expand and wedge into the sides of the hole. Be cognizant of the length of the anchor as it projects through the object being attached to the wall and how far it extends into the hole in the cinder block. The packaging will tell you what size holes to bore.
Stolen via Google Image Search
These are a variation that uses a wedge to expand the sides of the anchor as the screw is tightened, pulling the wedge through the anchor body and causing it to expand. Once it's tightened the nut can be removed and reattached to hold the object to the wall.
wedge anchor via Google Image SearchStolen via Google Image search
Both styles work well for cinder blocks and range from small diameter plastic sleeves for light-duty applications to heavy-duty anchors that use nuts tightened on a threaded shaft to expand the anchor inside the hole.
You'll want to pay attention to the length of the anchor if you're going to use this on any hollow parts of the cinder blocks. Unless these anchors have a surface to compress against (i.e. the sides of the drilled hole) they don't work very well and may not be able to be drawn down. You'll also have to consider the thickness of what you're attaching to the blocks.
If the wedge-style anchors are drawn down too tight they can cause lower quality cinder blocks to crack.
Stay away from crap like this:
You won't be happy with these. They suck.
Through Anchors:
These kind of anchors rely on going through the wall of the cinder block and expanding within the hollow area inside. This won't work if you have solid cinder blocks or are trying to locate the anchor in part of the block that's not hollow.
image stolen via Google Image Search
Essentially you drill a hole in the block, insert the anchor (while attached to the screw/bolt and allow the internal portion to expand and grab the inside surface of the block. This gives you something to tighten the screws against.
Here are some examples. With this one, you drill a hole in the block and insert the anchor while holding on to a nylon handle. You tighten a retaining collar against the outside of the hole while drawing the anchor tight against the inside of the hole. The collar holds the anchor in place until you can insert a screw through the item you intend to hang on the wall and tighten the screw into the anchor.
It sounds good on paper, but I've never had stellar luck with these. About 1 in 3 just don't line up right or the nylon "handle" breaks off causing the anchor to fall into the void of the wall.
These work by drilling a comparatively large hole in the hollow part of the cinder block and inserting the compressed "wings" while attached to the screw and the screw inserted through the board you want to anchor, into the hole. Once they clear the interior surface of the block, they expand and the screw can be tightened against the wings.
image ganked via Google Image Search
Depending on the thickness of the cinder block walls, considering the thickness of a 2x4 and some extra space for the wings to expand, you'll need 5" or 6" screws to get the wings inside the cavity of the cinder block enough to spring open.
The style with the retaining collar can be reused if the screw is removed. The style with the wings can't. When you remove the screw the wings fall down into the depths of the wall.
  • These are all the "best" way?
    – DMoore
    Oct 15, 2021 at 3:02
    "Best way" is relative. I stated that the Tapcons were my preferred way...but there are other options available. Each could be best depending on other factors not mentioned in the original question...except for those stupid plastic "twist up" ones.
    – gnicko
    Oct 15, 2021 at 3:12
  • I was looking to frame a wall basically and then attach it to the cinderblock fence. Are you suggesting that I lay the 2x4's with the flat portion of the the stud (the 4" portion) lay flat up against the wall? I was under the impression that I should frame my wall so that the 2" portion of my framed wooden wall is what comes into contact with the concrete cinderblock fence. Won't attaching the 4" portion flat up against the wall be more prone to warping?
    – Adrien
    Oct 15, 2021 at 9:23
  • @Adrien - Yes. Having complete information along with your question is always important. You'll have to plan out what materials you want to use and how you will build your wall. When it comes time to fasten your wall to the block wall, I've offered you several options. I suggest that you ask another question (or search for existing information) if you need help designing/building the wall.
    – gnicko
    Oct 18, 2021 at 1:47
  • @DMoore which is exactly why "best way" questions should be closed as opinion based - there is no way any of us can properly answer what's the "best way", especially when we're not given any criteria to define what "best" is.
    Nov 14, 2021 at 17:31
Assuming hollow cinerblocks...
You can drill a hole through the entire cinderblock and put a threaded rod with nut and washer on the other side, but that'll need your neighbor's agreement.
Otherwise, the strongest will be chemical anchor, it is also the most expensive and time consuming to use. The part that sticks out of the wall is a threaded rod, so you'll need to push it in to the right depth and drill a hole for the nut and washer in the 2x4 to make sure the nut doesn't poke out of the wood.
You can also use Mollies
Or plastic anchors
The chemical is about as strong as the conderblock, plastic anchors are weaker but they're much cheaper, so you can use more of them for the same price. Plastic anchors are also more practical since you can use normal wood screws which will sink into the wood and not poke out.
Since the 2x4s will be supported by the wall along most of their length, it makes no difference whether you lay them flat against the wall or narrow side against the wall. The wall will also prevent them from warping, but for that you need at least one fastener on top, one on the bottom, and one in the middle.
However if the wall is not flat, not plumb, or has mortar sticking out between the cinderblocks, you'll need to put some shims behind the 2x4s to adjust.
The 2x4s should not touch the ground to keep them dry, leave 1" or so.
