Hi all and thanks in advance for any tips given. I am doing a bit of DIY repairs of my leaking shower. Long story short I had to take down tiles, plasterboard, shower tray and replace part of subfloor damaged by the leak. Now putting it all back together again I aim to make it as waterproof as possible so would not have to suffer from the same a few years later. So far all is good and I'm at the stage ready to put tiles (large and heavy) back on the wall.
For the waterproofing among other thing i used tanking system Mapei Shower waterproofing kit . Which is basically a waterproofing membrane with flexi jointing tape which is to be applied across the perimeter. Next stage is to tile the shower and put silicon across the bottom edge.
This is how it looks currently:
Now the question: Imagine the silicon fails and water starts to get behind the tile. It won't be a problem all the way across the 3 walls of the shower due to tanking system. However, what if water would find its way across the perimeter to the outer corners of the shower tray?
2D illustration:
3D illustration:
With tiles being put into the shower such a leak would seem to go undetected behind the tiles and onto the subfloor again.
Is there a method, solution, system I could use to prevent such a leak?
Thanks you in advance for any tips!
