TL;DR: exposed wall of a brick room in a shed-like roofed structure, what to insulate with?
I live in a late 19th century log house in central Russia. It's got an uninsulated extension, as most of those houses did, that served as a sort of a vestibule, storage, attic access, and a wind- and rain-proof shed (here's a Russian Wikipedia link if anyone fancies an adventure in Google Translate).
The extension had a brick wall built in it that connects to the house and serves as the bathroom. I am now insulating this room. I've already replaced old insulation on its roof with 100 mm mineral wool, and planning on doubling that.
What remains now is a single exposed brick wall. It's shielded against rain and wind, save for an occasional stray drop or a draft, as well as from light. I'm guessing there's at least 100 millimetres of brick there, possibly 150 or even 200, but I have no way of knowing for sure. What should I use for insulation - mineral wool or PIR plates?
Using both would be hard, but I figure a few wall plugs (anchors) would do the trick.
  • Is foam-glass an option where you're at? It's non-combustible (like mineral wool) but vapor closed (like rigid foamboards) Oct 8 '21 at 1:12
  • @ThreePhaseEel I couldn't find any, nor have heard of the material before, though it seems very cool. I've got some fire-proof PIR plates, or at least they claim so, and in the very unlikely event of a fire the foam boards and the brick wall are the least combustible materials there - "perks" of living in a wooden house. Oct 8 '21 at 8:09
  • Yeah, most foamboards are somewhat fire-resistant (more like limited-combustible than non-combustible though) Oct 8 '21 at 11:46
  • AIUI, though, foam may melt instead of burning, but tends to release a lot of toxins. Just something for consideration and not intended to steer you away from foam.
    Oct 8 '21 at 14:40
