Does a subpanel need a grounding rod when the subpanel is within the same structure as the main panel?
Does a subpanel need a grounding rod when it is in an outbuilding?
Are there any distance considerations?
    No, but it needs to be connected to the building's grounding system and associated rods or other electrodes. Yes, No. And neutral and ground are always separate in a sub-panel, regardless of whether it needs a rod. And usually if it needs a rod, it needs TWO.
    Oct 7, 2021 at 18:17
  • @Ecnerwal, when does it need two? Just based upon the 25 ohm rule?
    – mongo
    Oct 8, 2021 at 19:26
No. Post-2008, system safety ground (Equipment Grounding Conductor) must be carried to all panels in the entire distribution, whether in the same building or a different building.
And also, each building needs a set of ground rods. But only 1 per building.
Officially "a breezeway" will turn 2 buildings into 1 building for NEC reasons. However, your AHJ may view that differently if you have a vast interconnected complex.
Generally speaking, too many ground rods "can't hurt, might help".
