I am mounting a TV above my fireplace and I am getting a bit anxious about the stud we are going to attach the mounting system on to.
After struggling for a while to find the stud we used a thin nail to measure where the center should be, and found that the stud was at least 2 1/2 inches wide! we drilled in, and all seemed normal, but our drill bit (which extends 2 1/4 in) felt like it got past the wood (only for the last 1/4 inch or so). Is it possible this stud is wider and shallower than the rest? Is there a non-invasive way to test it? I am mounting a TV thats about 20lbs. The wall mount is a full motion one, can't tell how much it weighs. Is this "weird stud" likely sturdy enough to mount the TV on? Is there a way to tell for sure?
It sounds like the stud is mounted sideways. Instead of 1.5" wide and 3.5" deep, it is 3.5" wide and 1.5" deep. That is not generally a good idea for regular framing. But it is quite common if a non-structural wall is built in front of a brick chimney over a fireplace, as cuts the total additional wall depth needed from 4" to 2". Absolutely normal and perfectly fine for supporting a TV.
There are two other potential issues to consider:
  • Height - Above a fireplace often means much higher than normal viewing height, which may be a little uncomfortable, depending on the size of the room, type of seating, etc.
  • Heat - TVs and fireplaces really don't get along. If the fireplace is for show only then this is a non-issue. If you plan to actually use the fireplace then I would seriously reconsider the location of the TV.
    Interesting, thanks! MY wife suspected it was sideways but we couldn't figure out why it would be. Oct 4, 2021 at 15:02
How thick is the wall?
It "flat framed" with 1.5" by 3.5" studs flipped sideways, to leave more room for the chimney. Or you are seeing a double stud, which is two 1.5" studs next to each other.
Either way, 20 lbs is quite light, and I would not worry at all about it.
