I am updating a 1993 house in Texas and now have exhaust fans going through the roof, so I am also adding a fresh exterior air intake to the HVAC return plenum for make-up air. I want to open the HVAC fresh air intake damper anytime ANY of the house's exhaust fans are ON (range hood, bathroom 1 exhaust fan, bathroom 2 exhaust fan, bathroom 3 exhaust fan), but have the damper closed when the exhaust fans are ALL OFF so that the HVAC properly circulates interior air. Already the HVAC system is barely adequate to circulate interior air without connecting to the outside (HVAC company didn't calculate the system size correctly), so I'm hoping the answer isn't just "don't use a damper; rely on barometric pressure".
There are three circuits involved (range hood, bathroom 1, and bathroom 2+3). Each fan is controlled by a wall switch. How should I wire the power for the HVAC intake damper? I don't want to end up with 3x110V to the fan when all the appliances are on, nor do I want to backfeed power into other circuits.
If this were software, I'd do something equivalent to an inclusive OR: ((IF power1=110V) OR (IF power2=110V) OR (IF power3=110V) OR (IF power4=110V)) THEN (damperpower=110V).
Please don't tell me to call an electrician or HVAC company; I've already gone through FIVE licensed "master electricians" who did NOTHING to code and one was so bad he nearly burned down my house with his mistakes; the licensed HVAC company which installed the HVAC system did everything wrong; and the city inspector is worthless -- greentags everything without checking anything -- even after I point out code violations to him (I've heard he may be accepting bribes from the contractors)!! It is one of those "if you want it done right, you have to do it yourself" situations. I minored in Physics and tutored an electrician through his electronics coursework, so I know this is in the range of do-able for me.
Thanks in advance for your advice!
