We just had heat pumps installed. I know that you cannot have the heat and the cool going at the same time. But can you have a head in fan mode and another head in heat or cool mode?
Sorry for the confusion. Only one heat pump outside, but there are 3 heads inside. We understand that we cannot put heat and cool on at the same time, but trying to determine whether you can put it in heat and fan or cool and fan. They can all run in just fan mode, but if one is in heat mode and 2 are in fan mode how does that effect the unit, since it is not pumping cold? How would I find out if a unit is capable of doing that?
