My front exterior door is inside a 9" jamb/pocket. The door installation should be pretty straight forward, however there is not currently a storm door, so I dont have an example of how the new storm door should be installed.
Door I am installing is standard 4 9/16 external door (pre-hung) and there are some wood pieces extending the jamb through to the exterior brick of the house.
One the exterior of the door are pilasters, crosshead, and pediment.
What I am trying to figure out is Where can I mount the storm door? There is no brickmold like in every install video I have watched. Also, If I tried this, there would be an 8" gap between the storm door and exterior door.
(Pilasters removed, so there will be an additional 2" when reinstalled)
door1
door2
  • Any chance of a picture? Is it 9" of brick in front of the door right now?
    – JPhi1618
    Sep 23, 2021 at 21:15
  • Remember there will pilasters which are an additional 2" thick mounted to the brick wall surrounding this door. ibb.co/D4dVZpm ibb.co/b2nRdnY
    – mikalsan
    Sep 23, 2021 at 21:24
  • @mikalsan -- as in decorative pilastering then? (as an aside: I'm not a big fan of architectural "plant ons" of that nature) Sep 24, 2021 at 0:24
  • @ThreePhaseEel, it is decorative. I removed all the old rotted wood stuff and ordered foam/pvc replacement. It will never rot again.
    – mikalsan
    Sep 24, 2021 at 12:20
  • @JPhi1618, the current depth of interior wood and exterior brick is 9". When pilasters reinstalled, it will be over 11"
    – mikalsan
The storm door should be installed on the existing door jamb, not the pilaster extensions. This would be the "standard" place to install it, and it should be structurally sound already because its holding the main door in place.
You may be able to install it on the pilasters, but they would have to be attached very well to the brick, also cover the top of the opening, and have a proper jamb at the bottom.
