I am redoing my cabinets. My primer and first coat of paint went on flawlessly - a beautiful finish. I have done all the prep properly, like sanding between coats, but for some reason I keep getting air bubbles that are leaving craters when it dries.
I am using Benjamin Moore Advanced with a Graco 360.
Any advice to fix this issue is greatly appreciated.
    (You can fix and improve your question using the "edit" link just below your post.)
    – TooTea
    Sep 23 at 7:49
    Sounds like offgassing. Did you wait a sufficient amount of time between coats for your climate?
    Sep 23 at 12:59
  • Yes,I waited 6 days to do the second coat.
    – Christal
    Sep 23 at 15:16
  • If you are using spray paint, keep the coating thin and without overlapping. Wait for it thoroughly dries, then add the next thin coat in the orthogonal direction to the first.
    – r13
    Sep 23 at 18:31
