I have this custom made stained glass piece that I want to fit inside my transom above a room door.
The picture shows wooden slats (1/2 x 1") used to hold the glass on one side, the other side being held by a clamp.
Should I put silicone in between the glass and the wood frame?
    Do you mean caulking? Why use silicone, in particular? There are a plethora of putties, caulks and other sealants, and in an interior door, none might be needed, except a speck to prevent rattling. Sep 22, 2021 at 22:15
  • I thought silicone just like you use silicone around bathroom fixtures.
    – amphibient
    Sep 22, 2021 at 23:12
  • @DrMoishePippik, should I use regular interior clear caulking ?
    – amphibient
    Sep 22, 2021 at 23:30
  • @DrMoishePippik, rattling is one of my primary reasons to have some kind of softish absorber
    – amphibient
    Sep 22, 2021 at 23:31
  • It doesn't seem too demanding. My preferences would be to use a bit of string putty, but silicone sealant might seep into the wood. Acrylic caulk also should work. Use the least possible amount, just enough to prevent rattling. Sep 23, 2021 at 1:58
While you could put silicone (or acrylic) caulk between the glass and wood, there's no need to.
  1. This very much appears to be an internal door. There's no need to prevent air or water transfer from one side to the other. Even if it's an external door, windows sashes like this are not normally installed that way.
  2. Any caulking will have an adhesive effect that will make it difficult to remove the pane in the future if any repairs (to the leading between the panes, replacement of a damaged pane, or the wood in the frame) should become necessary.
Your 1/2" x 1" wooden slats are usually called a "stop", and they're to hold one side of the window in place.
On the other side, you indicate that there is some sort of a "clamp" holding the window in place. Usually the other side is held in by several glazier's points*, I hope this is what you mean by a "clamp".
The glass is then trimmed out using glazier's compound on both sides. It is a non-hardening putty, similar to plumber's putty, that comes in a can or tub. You roll it in your hands to warm & soften it, then force it (by hand) into a fillet between the glass and wood, then tool it (with a tool or by hand) to a smooth, pleasing appearance. When done properly, it will make a weather tight seal that will hold for a decade or more for external use. Of course, for your interior transom, you only need it for appearance, as it's unlikely to rain on either side of the door, nor should you be worried about an air-tight seal there, either.
*Glazier's points are small, flat metal pins that are placed on the glass and pushed into the frame up to their built-in stops. The part that remains visible holds the glass, while the part that goes into the wood holds it tight to the wood. The visible part is then covered by the glazing compound. When installed properly, they will prevent any rattling. Oddly, my search for "glazier points" led me to a number of places to buy them, and a couple of instructions on how to install them, but not to anything that actually described what they are.
Glazier's points
    the clamp is temporary to take a picture
    – amphibient
    Sep 23, 2021 at 14:37
  • do you mean glazing compound?
    – amphibient
    Sep 23, 2021 at 14:39
  • @amphibient, this is the glazing compound I'm used to seeing. I never knew it came is a gunnable tube like that. I'm sure your link would work, I've just never seen it. (You know, watching This Old House, their window restoration experts use it from the tub, not a tube.)
    Sep 23, 2021 at 14:41
