I'm using this mosaic tile as a backsplash in our bathroom.
The gold spacers are a thin metal on top of another substance. The first three appeared to have some kind of ceramic under the gold facade and cut just fine with the wet saw. But two of the sheets have some kind of black rubber underneath instead, and the wet saw simply won't cut it. It cuts a bit on the edges, but once it's fully in there it simply won't push any further.
I'm hoping I'm just missing some pro technique here. The only option I could come up with was to cut each tile on the wet saw, then cut the rubber/gold on a table saw. That does NOT sound like a recipe for achieving a straight cut, but it's all I've got. Suggestions?
