Single-line 1 HP shallow well pump with preinstalled 5 gal pressure tank (one of these). Not attached to a well, but drawing water from a tank level with the pump.
After a year of disuse, I started it up today. The motor runs, but I cannot get prime. When I turn the power on: (1) With the priming port open, the surface of the water inside the pump is still. (2) The fan blades at the back of the motor do not turn freely.
From this, I am guessing that for some reason the impeller is not turning: Either the impeller or some other mechanical part in the pump is stuck, or the motor is not functioning correctly.
Any suggestions re next steps in troubleshooting? Take the pump apart?
    After a year of unuse, imagine seals and gaskets are dried out and/or broken. Probably will need to take pump section apart and replace seals.
    Sep 16 at 18:53
  • If it is a standard centrifugal pump if it spins it should work what type of pump is it? Even a photo could be helpful.
    Sep 17 at 19:13
  • Thanks, both. Added link to photo and some new information above. I now believe that the impeller is not turning.
    – Bolio
    Sep 17 at 23:40
  • What is the lift height?
    – Gil
    Sep 18 at 16:42
  • Lift height is zero, or maybe one foot. It is attempting to draw out of a tank level with the pump, for this test. This also matches how I would be using it.
    – Bolio
    Sep 20 at 10:40
