I had put a few EZ dry wall anchors for a curtain rod fixture. It was holding up great. Someone pulled on the curtain and one of the fixtures was pulled out with the dry wall anchors.
If it was up to me I'd just put the fixture a few inches down, since we have plenty of wiggle room, but it's not up to me.
So I need to re-attach the fixtures to the same exact spot.
I know plastering the holes won't be strong enough. I don't want to have to cut a huge square of the drywall out -- unless that is the only way.
Picture of the holes:
One thought I had was to use a bigger/better drywall anchor like this but I don't know enough about this field to know if that'll hold up.
    With having to use same hole placement, will need to use a toggle bolt/screw type that anchors to the back of the drywall. Myself do not really like plastic types, but it should work. Holes look almost big enough for them now with a bit of cleaning up.
    Sep 16, 2021 at 11:56
  • An EZ Toggle should fit through the old holes. Sep 16, 2021 at 13:24
    @crip659 - toggle bolt, +1... and a hammer to "clean" it in there.
    – Mazura
    Sep 16, 2021 at 15:48
The easiest answer to this is a new, bigger drywall anchor - but these usually require new, bigger screws (thicker shaft, and likely a larger head). At some point, this approach becomes a bad idea, the screws can get too big and the anchors ripping the wall too much.
There are various different types of anchors, similar to the one you linked. Consider any of these as a replacement for the anchor that got ripped out:
These are all larger and more powerful than the ordinary anchors that are typically included with curtain rod mounting hardware kits.
Sometimes the area near windows like this has studs/framing behind it (yours doesn't appear to, but anyone else viewing this answer would do well to look for that first) and while framing is a better mount point for screws directly, it doesn't work well at all with these kinds of anchors. Look for framing before drilling holes for anchors, you may just need to screw directly to the framing.
  • Okay. Going to go get some to try. Will mark answered if it works. Thanks! Sep 19, 2021 at 20:22
  • Gotta disagree about that picture - the third one is a pretty standard rawl-plug, and is totally unsuitable for plasterboard. Second one is poor - only the bottom one really counts as "good" in my books.
    – MikeB
    Jul 25, 2023 at 10:39
